Practical Notes for Using a Power Bank with Columbus P-70 Ultra, P-9 Race, and P-7 Pro
Quote from GPSWebShop Official on April 2, 2026, 2:37 pmWhen using an external USB power source such as a power bank with low-power GNSS receivers like the Columbus P-70 Ultra, P-9 Race, and P-7 Pro, there is one practical point to keep in mind.
Some power banks may auto shut off
These receivers use very little power, which is great for long operating time. However, some USB power banks may automatically enter sleep mode when the connected device draws too little current.
This means:
some power banks work normally
some may shut off automatically after a while
some only support low-current mode for a limited time
The issue is usually not battery capacity, but whether the power bank can stay awake under low current draw.
Example: P-70 Ultra power consumption
The complete P-70 Ultra unit requires about:
5V / 80mA average
about 0.4W
Actual current draw may vary roughly between 60mA and 100mA.
So even a small power bank can provide long runtime. The main thing to check is whether the power bank will remain on.
Recommended solution: USB dummy load
If your power bank shuts off automatically, a simple solution is to use a USB dummy load.
Example: https://www.amazon.ca/Interfaces-Stabilizers-Electronics-Continuous-PowerBanks/dp/B0GS39MW4F
A dummy load adds a small extra current draw to keep the total load above the power bank’s sleep threshold.
For example:
GNSS receiver: 80mA
Dummy load: 25mA
Total load: 105mA
If the power bank sleeps below 100mA, this setup can help keep it running continuously.
Practical recommendation
When using a power bank with the P-70 Ultra, P-9 Race, or P-7 Pro:
first test whether your power bank can power the receiver continuously by itself
if yes, no extra accessory is needed
if it shuts off automatically, add a USB dummy load
set the dummy load only as high as needed
If you have any questions about your setup, feel free to contact us.
This means:
5V / 80mA average
about 0.4W
For example:
GNSS receiver: 80mA
Dummy load: 25mA
Total load: 105mA
