Forum breadcrumbs - You are here:Support ForumsNavisys Products: Navisys GR-9029My device is having trouble enter …
My device is having trouble entering RTK mode.
anonymous@jackshu2020
#1 · July 4, 2023, 2:57 pm
Quote from anonymous on July 4, 2023, 2:57 pmMy device is having trouble entering RTK mode. Even though the BASE: status says "DATA_MODE" and I see an active Byte Rate:, I can never acheive "FIXED_RTK" and instead I only get "FIXED_GPS". I've attached screenshots.
Thank you for your help.
Click for thumbs down.0Click for thumbs up.0
GPSWebShop Official@jack
#2 · July 9, 2023, 12:44 pm
Quote from GPSWebShop Official on July 9, 2023, 12:44 pmAccording to your data, following reasons may result GR-9029 unable to enter into RTK mode.
- The distance (483 KM) of GR-9029 is too far away from the RTK BASE. This long distance does not fit the requirements of RTK baseline. It will be suggested to use a RTK BASE within 20 KM. The shorter the RTK fix is faster and accuracy is better.
- According to your screen shot photo, there are only 10 satellites. Its accurday is about 170 cm. It may be that GR-9029 is not located in the environments of open sky. It will be suggested that you do the test again under open sky.
