Forum breadcrumbs - You are here:Support ForumsColumbus Products: Columbus V-1000How to Configure Columbus V-1000 …
How to Configure Columbus V-1000 to Log Altitude Data with Vertical Accuracy Up to 1 Meter?
GPSWebShop Official@jack
#1 · June 24, 2023, 9:37 pm
Quote from GPSWebShop Official on June 24, 2023, 9:37 pmThe V-1000 comes equipped with a BOSCH barometric sensor, widely recognized as the highest-performing sensor in the industry. By utilizing this cutting-edge technology, you can achieve greater vertical accuracy by following the configuration steps outlined below:
- Press the "Up" button until you see the "Settings" option, then select it.
- From there, select "Operating Modes" → "GPS Mode".
- To pre-calibrate the altitude, go to the "Settings" menu and select "Setup" → "Altimeter Cal" → "On".
- Using the up and down buttons, select the current elevation value, which you should obtain in advance from another source.
- Enter the value and press the "Select" button to save the setting.
Following these steps will enable you to achieve an altitude accuracy of up to 1 meter.
Click for thumbs down.0Click for thumbs up.0
