Forum breadcrumbs - You are here:Support ForumsColumbus Products: Other Columbus ProductsColumbus P-1Has my Columbus P-1 / P-10 Pro lo …
Has my Columbus P-1 / P-10 Pro logger stopped working?
GPSWebShop Official@jack
#1 · June 25, 2023, 8:29 pm
Quote from GPSWebShop Official on June 25, 2023, 8:29 pmThe symptom:
The P-1 / P-10 Pro will not charge or turn on. The charging light does not turn on when plugged in to a usb charger. It also will not turn on when the power button is pressed.
The solution:
There is a small hole next to the usb port in P-1 / P-10 Pro. You can insert a pin to reset the unit. Please connect the charger and do the reset at the same time.After reset, the P-1 will become normal.
The symptom:
The solution:
Click for thumbs down.0Click for thumbs up.0
