Could you explain the difference between “IMU Calibration” in the “Device” menu and “IMU Initialization” in “Point Survey”?
IMU Calibration (Device Menu):
This function calibrates the IMU module to maintain accuracy. Over time, factors like prolonged use, vibration, or dropping the GNSS device can reduce IMU accuracy. Calibrating the IMU helps restore its precision, ensuring an error of <2 cm.
IMU Initialization (Point Survey Menu):
IMU initialization is required each time the device is powered on. For the G50, this process is simple and usually completes after walking a few steps. In some cases, users may need to manually shake the survey pole to finalize the initialization.
