The occurrence of "5 short beeps" indicates a file format error. This usually happens when the "CONFIG.TXT" file used to configure the P-10 has an incorrect format. The problem often arises from the absence of the last two characters, specifically a CR and LF, at the end of the CONFIG.TXT file. Adding a line break at the end of the file will resolve the issue. Please refer to the screenshot below for clarification.
