Is there a way to turn off the status LED or lock the power button? The units will sit on the shell and get pressed against burrow walls.
The standard firmware does not provide an option to disable the status LED or lock the power button. The LED only flashes intermittently and has relatively low brightness, so its environmental or biological impact should be limited.
We recommend evaluating both the LED and button behavior with the pilot units under actual field conditions. If stricter control is required, custom firmware may be possible, subject to a minimum order quantity.
