How to record Raw GPS for static on P-7 pro
Quote from CuongCRE on September 6, 2023, 11:07 pmSometimes I need raw data for static processing and PPK, so how P-7 pro can record Raw data?
Thanks,
Thanks,
Quote from GPSWebShop Official on September 7, 2023, 10:56 amNo, the P-7 Pro doesn't support raw data output. Another option is the Columbus P-9 Race GNSS receiver, which does offer basic raw data output. However, it lacks "Carrier Phase" data, making it unsuitable for PPK processing.
If you require a GNSS receiver capable of full raw data output, including "Carrier Phase," you should consider RTK GNSS receivers. A recommended option is the TOP608BT.
For further guidance, you can refer to this article on using the TOP608BT to collect complete raw data: How to Obtain a Highly Accurate Coordinate for Your RTK Base Station.
