How to connect P-70 Ultra to Android and ArcGIS Field Maps?
Quote from anonymous on June 12, 2026, 10:54 amHello,
It does not connect the Android Device 'Blackview' with bluetooth. It does find the Columbus P-70 Ultra, all 4 channels and does pair, but does not connect. I tried many options such as developer mock and NTRIP Lefebure Design client. Some applications such as GNSS status or ArcField Maps says 'no data is being transferred'.If you can help me out,Thank you
Hello,
Quote from GPSWebShop Official on June 12, 2026, 10:56 amFor P-70, there are 4 bluetooth channels(2 spp and 2 ble). For Android, you could use the 2 SPP channels).
The P-70 Ultra NTRIP SPP channel is for ntrip data up stream to the P70 from Android device
The P-70 Ultra SPP channel is for GNSS positional data (such as NMEA) down stream to the Android device from P70
here is the bluetooth pairing instruction:
https://cbgps.com/p70/support/manual/knowledge/bluetooth/knowledge_bluetooth_android_en.htm
here is the ArcGIS Field connect instruction:
https://cbgps.com/p70/support/manual/knowledge/fieldmaps/knowledge_fieldmaps_en.htm
