GR-M02 GNSS Aiding (A-GNSS) Support: Time, Position, Almanac & Ephemeris
I’d like to know whether the GR-M02 supports any GNSS aiding features to reduce Time to First Fix (TTFF).
Specifically, does the module support any of the following via the serial interface?
  • Setting the initial date and time
  • Setting an approximate initial position (latitude/longitude)
  • Uploading almanac data
  • Uploading ephemeris data
If these features are supported, could you please provide the relevant commands or documentation?
Thank you!
* Setting the initial date/time via the serial interface
->Please see following command
[Packet Type]
   590
[Command]
   PAIR_TIME_SET_REF_UTC
[Supported Chips]
   AG3335 / AG3353 / AG3365
[Note]
   This configuration will not keep in the flash or RTC RAM. Please send this command every time after the GNSS subsystem or main power reboots.
[Description]
   Send current UTC time to GNSS chip for faster TTFF.
   Please do not use local time which has a time-zone offset
   For a faster TTFF, the accuracy of reference UTC is better if it is less than 3 seconds.
[Data Field]
   $PAIR590,<YYYY>,<MM>,<DD>,<hh>,<mm>,<ss>*CS<CR><LF>
       YYYY  year    > 1980  UTC time: year in 4 digits
       MM    month   1 - 12  UTC time: month
       DD    day     1 - 31  UTC time: day
       hh    hour    0 - 23  UTC time: hour
       mm    minute  0 - 59  UTC time: minute
       ss    second  0 - 59  UTC time: second
[Return]
  1. PAIR_ACK for send result.
[Example]
    1 Send:
    2     $PAIR590,2019,2,10,9,0,58*0B\r\n
    3 Response:
    4     $PAIR001,590,0*37\r\n ==> Success
* Setting an approximate initial location via the serial interface
[Packet Type]
   600
[Command]
   PAIR_LOC_SET_REF
[Supported Chips]
[Note]
   This command will get a failed response if GNSS-SubSys does not power on. You can get the GNSS-SubSys status by PAIR_GNSS_SUBSYS_GET_STATUS.
[Description]
   Send reference location to GNSS chip for faster TTFF.
[Data Field]
   $PAIR600,<Latitude>,<Longitude>,<Height>,<AccMaj>,<AccMin>,<Bear>,<AccVert>*CS<CR><LF>
   Latitude: reference latitude in degrees
   Longitude: reference longitude in degrees
   Height: reference height in meters
   AccMaj: semi-major RMS accuracy [m]
   AccMin: semi-minor RMS accuracy [m]
   Bear: Bearing in degrees [Range: 0~179 degrees]
   AccVert: Vertical RMS accuracy [m]
[Return]
[Example]
    1 Send:
    2     $PAIR600,24.772816,121.022636,175.0,50.0,50.0,0,100.0*18\r\n
    3 Response:
    4     $PAIR001,600,0*3D\r\n ==> Success
* Uploading almanac or ephemeris data
->We do implement this function in our tracker products. However, this function is limited by our NDA with chip vendor. We are not able to open related documents.
If yes, do we have any documentation or command reference for these features?
->We will add above two commands in our next data sheet release.
your answer on forum is a bit incorrect, the device does not like the example command.
With tries I was able to feed this line
$PAIR600,24.772816,121.022636,175,50,50,0,100*18
this is the reply by device:
$PAIR001,600,0*3
D..$PAIR600,24.7
72816,121.022636
,175,50,50,0,100
*18..
Could you please fix it, so other people will not struggle.
Thanks for pointing this out! You’re correct.
$PAIR001,600,0*3D..$PAIR600,24.772816,121.022636,175.0,50.0,50.0,0,100.0*18
The “..” is non-printable <CR><LF> or 0D 0A in hexadecimal. Normally, it looks like below if <carriage return> and <line feed> were correctly set in terminal tool.
$PAIR001,600,0*3D
