What’s the continuous long beep means after the device is turned on?
Quote from GPSWebShop Official on June 24, 2023, 10:11 pmIf the device makes the continuous long beep after powering on, it means the memory card is abnormal during the startup of the device. Please open the rubber cover at the bottom of the device to check if your Micro SD card is installed incorrectly. Please re-plug the Micro SD card and install it properly, then restart it to confirm whether to eliminate the continuous long beep problem. If the problem is remained, it might be memory card problem. It is recommended to use the utility program to perform FAT32 formatting on the memory card. **Please note that this action will erase all data on the memory card.
