Questions and Answers
Quote from GPSWebShop Official on June 25, 2023, 9:15 pmQ1What's the difference between NAV and LOG?
A1
NAV : BT-Q1000XT can be used to navigate with handheld devices (PDA / Smartphone / Laptop), but the data log function is disabled.
LOG : BT-Q1000XT can be used to record your travel path and for navigation simultaneously.Q2
I lost my travel charger and battery. Where can I find replacements for both?
A2
DC Input range of BT-Q1000XT is 4.5~5.5V. You can also use a common mini USB cable to charge your unit via the PC. Besides, the battery for BT-Q1000XT is compatible with Nokia phone series. The battery model is BL-5C.Q3
How can I know if my memory is full?
A3If you see the orange GPS light is turning from orange to solid red, then it means the memory is full.
Q4
Can the logged data be downloaded by Bluetooth?
A4
Actually it's okay for Q1000XT to download data via Bluetooth interface. However, since it is not stable and may have lower download performance than USB interface. We don't officially admit this feature.Q5
How can I adjust my device to 5Hz mode?
A5Please download the tool, ”QstarzGPSView” from our website to adjust.
Q6
My navigation software does not support baud rate 115,200. How can I make it work via USB interface with Qstarz GPS?
A6
When Qstarz GPS is connected via USB interface, the baud rate is fixed and should be set to 115200. If your software does not support this baud rate, please connect the device via Bluetooth interface whose baud rate is changeable.Q7
When I use QTravel software to read log from device, it appears "No Data in Device." Why?
A7
Q1000XT will not log invalid GPS data (GPS with no fix). So please make sure to log valid GPS data under open sky environment. If the logger still cannot log, please perform a reset in QTravel -> Config GPS.Q8
My Travel Recorder cannot log 5Hz data?
A8
The update rate stands for the rate of GPS refreshing NMEA data received from satellites. Thus 5Hz update rate only means GPS can receive or refresh NMEA data 5 times per second, and it's irrelevant with 5Hz logging.Q9
How can I set the time schedule function?
A9
Please set the BT-Q1000XT from Qravel->Config GPS->Schedule. Select the schedule you want, and change device switch to “NAV” mode. It will enter into sleep mode after 10 minutes for saving power and it will only wake up and start to record data when the time meets your preset time schedule.Q10
Will your device work with the iPad or iPhone?
A10
Our device can support iOS by "Jailbreak" the iPhone/iPad and use the application “Roqy” to connect external Bluetooth GPS antenna to your iPhone/iPad. Please refer to the website below : http://www.roqy-bluetooth.net/wp/Q11
Is there any way to get the software for a Mac?
A11
All of our software does not support mac OS.
The alternative way is using the following third party software.
Download log data:
http://www.houdah.com/houdahGeo/
http://sourceforge.net/projects/bt747
Geotag:
http://code.google.com/p/gpicsync/Q12
Could you provide a Linux driver?
A12
So far all of our software does not support Linux platform. However, there is a third party software which is Linux compatible with our products. Below link is for your reference:
http://www.bt747.org/de/installQ13
How can I change the NMEA sentence?
A13
Please download the tool “QstarzGPSView” from Qstarz website to adjust NMEA sentence.Q14
How can I transmit log file to an android phone via Bluetooth? It is able to pair but cannot connect.
A14
Please download free software ”Bluetooth GPS” and “Mytrack” from Android Market. Download the data files via Bluetooth from BT-1000XT to your Android smart phone. Please refer to the website below:
https://market.android.com/details?id=com.google.android.maps.mytracksQ15
What is the “drift function” means?
A15
The “Drift” function is to correct the way points by deleting the low speed way points.Q16
Why the track recorder’s recorded track points is far away from the actual position?.
A16
The drift point may be caused by slow speed or when you stay at a fix position for a while.
Drift Filter can correct the GPS deviation especially when the GPS is situated in low speed status.Q17
I get a message that says "FAILED TO CONNECT GPS MODULE. “ Can you help?
A17Please Check connection COM port at Windows Device Manager -> Com&LPT -> GPS USB…..or CP210X…… And manually select connection COM port at Software>Config GPS and test again.
Q18
I am having trouble to Upload AGPS data. What can I do?
A18Please download QstarzGpsView from Qstarz website and download AGPS from Setup->Update AGPS
Q19
How can I geotag my photos?
A19The GPS real time is based on UTC/GMT+0 time. What you have to do is to change UTC/GMT to your local time zone by selecting Display time zone in software.
And set the correct local time with your camera. When you import the pictures from your camera, the photo time will be synchronized automatically with the local time.Q20
How can I set the time on the GPS unit?
A20Sorry, you could not set the GPS time, all of our GPS products is using the universal UTC/GMT time.
http://www.worldtimeserver.com/current_time_in_UTC.aspx This means no matter where you use the device, the GPS time will be the same (UTC/GMT time) and the GPS device time could not be changed or modified.Q21
How can I turn off the buzzer?
A21Please turn off the buzzer from QTravel ->Config GPS and uncheck the “Turn on buzzer” function.
Q22
How can I turn off the Vibration Detector?
A22
Please disable the Vibration Detector from Software->Config GPS-> and uncheck “Turn on Vibration Detector”Q23
Why am I getting the Google Maps API error message pop up and cannot use the map function, what can I do?A23
Please download and update to the latest version of the software from our website to solve this problem.
A1
Q2
A2
Q3
A3
Q4
A4
Q5
A5
Q6
A6
Q7
A7
Q8
A8
Q9
A9
Q10
A10
Q11
A11
Download log data:
Geotag:
Q12
A12
Q13
A13
Q14
A14
Q15
A15
Q16
A16
Q17
A17
Q18
A18
Q19
A19
Q20
A20
Q21
A21
Q22
A22
Q23
A23
