How do I update the firmware of my BL-1000GT device?
Quote from GPSWebShop Official on June 24, 2023, 10:10 pma. Before proceeding updates, please make sure the device is power off. Connect device to your computer with a Micro USB cable, and make sure that the battery is installed and has more than 40% battery life.
b. Open the file ” Download Index_BL-1000GT.HTML “ in the device memory, or go to the Qstarz official website(http://racing.qstarz.com/Download.html) to download the latest firmware.
c. After opening the file manager, copy the firmware file FW.QST to the root directory of the device’s memory card. After the copy is completed, right click on the file manager icon and select Exit. The computer will be shown the message "You can safely remove the hardware".
d. After removing the micro USB cable, the device will automatically perform the firmware update. The firmware update process takes about 1~2 minutes. Do not operate the device during this process to avoid the device update failure. The middle three LED lights will flash in turn. After the update is completed, the device will automatically shut down after two beeps, which means the update is completed.
