FAQ
Quote from GPSWebShop Official on June 25, 2023, 9:13 pmProduct Installation
Q1: How to install the i-gotU Travel Logger (how to connect with the PC)?
Q2: How to check whether i-gotU device has been installed successfully?
Q3: How to confirm whether i-gotU device can work without any problem?
Q4: Is i-gotU device compatible with Mac-OsX?
Software Operation
Q1: How to import my Travel Logger data into @trip PC?
Q2: How to backup (export) my initial track data (GPX file)?
Q4: How to see the information (Attributes) of my waypoints?
Q5: How to change the template?
Q6: Can I immediately record Waypoints anytime? Where can I find them (waypoints of Push-to-Log)?
Q7: How to check the current setting of “Tracking Interval”?
Q8: What is "Smart Tracking Mode" function?
Q9: Why Google Map does not show all of my waypoints on the track?
Q10: How to improve my waypoints which are not so accurate?
Q11: How to export the GPX from i-gotU Desktop software V1.0 and import to @trip PC software V2.0?
Q12: How to embed my trip in the other blog?
Q13: What can I do if the windows-Popup a "I-gotU Desktop platform EXE" problem?
Q14: How to change my template to "Sport" mode?
Q15: How to merge multi-tracks?
Q16: How to backup of all data on pc? Or can I download all trips record back to my PC?
Q17: How to combine several trips into a single trip?
Q18: Why my GPS Logger cannot download GPS data to PC since 2016/1/1?
Q19: How to check your GT-120/600 device firmware version & software version?
Hardware Operation
Q1: Why does the i-gotU device locate for so long or even cannot locate the position?
Q2: Why there is not any response when I press the button of the i-gotU device?
Q3: How much data can i-gotU device store?
Q5: How long will the i-gotU device finish locating and start to record after I turn on the power?
Q6: How can I do when I forgot the password after setting "Enable Password"?
Q7: Will the time record change if I go to different time zone?
Q8: Can I change the battery of the i-gotU device?
Q9: How long can I use the i-gotU device before the battery run down (Battery Life)?
Q10: Is it waterproof or moisture-proof?
Q11: Can I connect the i-gotU device with the PC to work as GPS device?
Q12: How to adjust time of the i-gotU device?
Q13: How to judge the LED indicators of i-gotU device quickly?
Q14: Is there any solution for the i-gotU battery which can not be replaced?
Software Operation
Hardware Operation
